Wiper problem
Old Dec 24, 2012 | 12:16 PM
softail817's Avatar
Wiper problem
Have a 74RR, the wipers won't park, they shudder a bit then die, replaced both the motor and the switch still having the same problem, any advice?
Old Dec 24, 2012 | 05:12 PM
Chryco Psycho's Avatar
Contact Kim AT Passion 4 Mopars
Old Dec 24, 2012 | 07:48 PM
Mr.4spd's Avatar
Ballast resistor.
Old Dec 25, 2012 | 05:56 AM
softail817's Avatar
really?, how would the ballast resistor be involved with the wiper motor?
Old Jan 12, 2013 | 04:52 PM
bigblock's Avatar
2 speed wipers have a ballast to make the first speed slower than the second.3 speed wipers dont have this.You must have 3 speed wipers.You need to find out what the car came with,to make sure the new parts you installed are compatible.
Old Jan 17, 2013 | 07:42 PM
softail817's Avatar
Car has a 2 speed switch, replaced the motor with what was in there when I got the car.
Old Jan 17, 2013 | 08:09 PM
Mr4spd failed to clarify. Your wiper motor itself has a ballast resistor mounted on it.
Old Jan 18, 2013 | 04:44 PM
Just to be correct, not every resistor is a "ballast." That resistor is in there for part of the speed control.
The whole idea of a "ballast" is to either regulate voltage or current, depending on the application. Ballasts are designed with materials which change resistance because of more/ less current, and therefore change current through the load.
Lamps are an example of changing resistance. A cold lamp draws a LOT more current when first starting to heat up than when after it's at full brilliance. This can become a problem in such things as very large power transmitting tubes. A "used to be" popular amateur radio PA tube "back when" was either a 3- or 4-1000A. These tubes had big filaments, They draw 21 amps at 7.5V, so two tubes are double that amperage.
An amateur radio "4 x 1" amplifier
Larger tubes are even more problematic An Eimac tube with 1 megawatt dissipation (that's right, 1 million watts) and capable of over 2 MW output in class C/ FM service, has a filament that runs at 16.3V at a whopping 625 amps!!!! You don't just turn those things on, as the cold "inrush" current is fantastic. The anode is liquid cooled:
http://home.comcast.net/~n6jv/data/X2159%20Ad.jpg
http://www.tubecollectors.org/eimac/archives/8974.pdf
68satellite
May 18, 2009 06:35 PM
baghdad 1
Jul 24, 2008 09:52 AM
Piero
May 2, 2008 09:26 AM
siliconcrunch
Jan 4, 2008 11:22 PM
75plyduster
Nov 19, 2007 12:51 PM
