wiring problem???
Old Nov 30, 2008 | 06:30 PM
skrewball1211's Avatar
Junior Member
wiring problem???
I have a 1967 dodge Coronet 500 with a 318. The other day I was in the drive thru and noticed a smell coming from the dash. Within a few seconds a saw a bit of smoke come out of the heater controls. When I got home I check the wiring, but found no frayed or burned wires. I was wondering if anyone has had experienced that problem or would know what the problem could be. Any help would be appreciated.
Old Nov 30, 2008 | 06:47 PM
did anything look wierd or go off on the dash?
Old Nov 30, 2008 | 07:05 PM
Junior Member
Not that I am aware of, but I do recall hearing a low whirring sound prior to this happening. Thanks for the quick response. Cheers.
Old Nov 30, 2008 | 08:06 PM
64fury's Avatar
I had the issue with my 64' last year. the old factory wires were getting so old and worn there were cracks and shorts all along the length of the harness. It started out with a short under the dash in the fan motor switch but by the time I was done I had to replace the entire wiring harness with one from painless. Hope it's not as bad for you!
Old Dec 1, 2008 | 07:31 AM
muggsy's Avatar
Yes, I have had this happen recently and found out that my entire dash harness was melted and I am lucky it didn;t go all the way to the alternator. I noticed it just in time. Could have been trouble. Make sure you check this out fully ASAP. Its no joke.
Old Dec 1, 2008 | 07:35 PM
Junior Member
Thanks for the advice guys I really appreciate it!!!!
Old Dec 3, 2008 | 03:56 PM
ef8340's Avatar
Senior Member
check the bulkhead connections also mine was in that area
rc-ltu
Feb 8, 2011 09:00 PM
RROriginals
May 8, 2010 07:33 PM
fishpwr
Sep 25, 2008 03:37 PM
dbaughman
Apr 5, 2008 08:53 AM
wtim47
Cuda Specific Discussion
Jun 8, 2007 04:51 PM
