1966 Fury III engine
I have a 1966 Plymouth Fury III and The VIN says I have a 318 "LA" engine, but I dont have the same(or at least I think) valve covers as an LA, It looks like I have a Poly 318 "A" engine(there are two bolts ib the middle of the valve cover). Is this something significant, or could someone have done an engine swap and changed it from an "LA" to an "A"? And also where is (if there is) a casting number or some sort of number that tells me what the info on the engine?
its a poly "a" motor 100% i have the same in my 66 dodge coronet. Also they made the 318 poly "a" motor until 1967 on Canadian applications. Parts are very hard to find, definitely look into swapping the 318 for a bigger motor, because like i said parts are pretty scarce and/or cost a fortune.
________________________
1966 Coronet 440 318 poly
solm96@me.com
Jul 10, 2010 08:35 PM
