1966 Fury III engine
Old Oct 27, 2011 | 12:07 AM
Arbiter343GS's Avatar
I have a 1966 Plymouth Fury III and The VIN says I have a 318 "LA" engine, but I dont have the same(or at least I think) valve covers as an LA, It looks like I have a Poly 318 "A" engine(there are two bolts ib the middle of the valve cover). Is this something significant, or could someone have done an engine swap and changed it from an "LA" to an "A"? And also where is (if there is) a casting number or some sort of number that tells me what the info on the engine?
Old Oct 27, 2011 | 12:16 AM
I will also post a pic of the engine when I wake up in the morning.
Old Oct 27, 2011 | 11:14 AM
Here is a pic of the engine and the valve cover
Attached Thumbnails 1966 Fury III engine-engine.jpg   1966 Fury III engine-valve-cover.jpg
Old Oct 27, 2011 | 07:03 PM
66 was the last year for the poly 318.I would suspect they used them until the supply ran out. Then switched to the new LA318
Old Oct 27, 2011 | 09:30 PM
I had a feeling it was something like that.
Old Oct 30, 2011 | 06:57 AM
thohill's Avatar
yeah absolutely. check which month the car was produced.
Old Oct 30, 2011 | 05:22 PM
February
Old Oct 30, 2011 | 05:46 PM
66coronet440's Avatar
its a poly "a" motor 100% i have the same in my 66 dodge coronet. Also they made the 318 poly "a" motor until 1967 on Canadian applications. Parts are very hard to find, definitely look into swapping the 318 for a bigger motor, because like i said parts are pretty scarce and/or cost a fortune.
________________________
1966 Coronet 440 318 poly
Old Nov 11, 2011 | 02:12 PM
bboogieart's Avatar
Maybe just a later 318. a lot less head ache.
MisterFury
17
Sep 23, 2012 07:50 PM
MisterFury
Aug 23, 2012 06:30 AM
Arbiter343GS
Aug 1, 2012 08:23 PM
fury_19
Jun 25, 2012 02:53 AM
solm96@me.com
Jul 10, 2010 08:35 PM
