| jumpr71 |
Feb 20, 2014 02:57 PM |
Hey all...thank you very much for suggestions on where to start looking. Drag my thermostat was closed when I fired it up yesterday afternoon. I fired it up and drove about 12 miles today, and the heat was working. I never went over 50 though. 440...I do have a shop manual. I am going to check to see if it has a water control valve this afternoon. Its a factory a/c car, and the a/c works. Belts are new, and temp gauge is not accurate. New sender in my toolbox, just haven't had time to put it in. Started to yesterday, but my apartment complex received a complaint about my car so I had to stop :D . What I find hysterical is that my car is almost as quiet as the day it rolled out of the factory, having just installed new mufflers. Its timing is spot on, my carb is tuned in, and my old 383 is finally running as it should...with the exception of the heat. Nobody else has a 47 year old daily driver in my complex though...a lot of Volvos and Lexus. The neighbors should be happy my daily driver isn't some open header model A, or something equally loud...
