1966 Fury III...lost heat at highway speed...
Old Feb 19, 2014 | 03:04 PM
jumpr71's Avatar
I was driving down 217 here in Oregon, and I noticed that all of a sudden my heater is blowing cold air. When I slowed down, the air warmed up again. It seems that under load my heater is blowing cold, and when I get back down to under 50 mph it gets warm again. I am at a loss...head gasket?? Air bubble in the heater core?
Old Feb 19, 2014 | 03:10 PM
Check the water level !
Old Feb 19, 2014 | 03:14 PM
jumpr71's Avatar
Opened the radiator shortly after I got home, and it was full...
Old Feb 19, 2014 | 05:09 PM
Look to see if there is a mechanical valve hooked into the heater hose ??
Old Feb 19, 2014 | 05:18 PM
Drag Pak's Avatar
Thermostat stuck open?
Old Feb 19, 2014 | 06:12 PM
What is the temp gauge doing?
Have you checked the belt?
Does it have a water control valve (probably vacuum?)
I didn't bother to look up the heater in a 66, is this a factory AC car or heat only?
You have a shop manual?
Might be a blend door not working
Old Feb 20, 2014 | 02:57 PM
jumpr71's Avatar
Hey all...thank you very much for suggestions on where to start looking. Drag my thermostat was closed when I fired it up yesterday afternoon. I fired it up and drove about 12 miles today, and the heat was working. I never went over 50 though. 440...I do have a shop manual. I am going to check to see if it has a water control valve this afternoon. Its a factory a/c car, and the a/c works. Belts are new, and temp gauge is not accurate. New sender in my toolbox, just haven't had time to put it in. Started to yesterday, but my apartment complex received a complaint about my car so I had to stop . What I find hysterical is that my car is almost as quiet as the day it rolled out of the factory, having just installed new mufflers. Its timing is spot on, my carb is tuned in, and my old 383 is finally running as it should...with the exception of the heat. Nobody else has a 47 year old daily driver in my complex though...a lot of Volvos and Lexus. The neighbors should be happy my daily driver isn't some open header model A, or something equally loud...
Flame
Aug 12, 2015 11:55 AM
The Quiet Guy
Dec 29, 2013 09:42 PM
Crazy4Carz.Com
Jul 5, 2012 12:32 AM
fury_19
Jun 25, 2012 02:53 AM
c011699
Apr 11, 2010 03:27 PM
