451 stroker set up
451 stroker set up
hello out there,
I've got a 451 stroker. Had it built new, but got never received the build sheet. I think they put a 509 Hughes Cam. 800CFM Thermoquad and I'm running full Msd Ignition set up 6Gal Box, pro billet distributor and blaster 2 coil…
How would you set your timing?
I really can't say with confidence. Maybe 902 heads? I know that there is adjustable valve train (Hydrolic).. All I know is that they came off of a cuda and they've had work done, but like I said.. I never got the build sheet.
