65 Fury Door Latch
Old Dec 23, 2009 | 10:36 AM
CoogarXR's Avatar
Junior Member
65 Fury Door Latch
I have a problem with my 65 fury rear door latch sticking. I have to hold the handle and ram into the door with my shoulder to make the door open!
If I hold the door open, I can turn the sprocket while holding the door button or the inside lever. It clicks into place when I let go (like it should). If I shut the door very gently, it opens like normal. If I shut it normally (harder, but still not a slam or anything...) it sticks.
It is driving me nuts. Any ideas?
CoogarXR
Old Dec 23, 2009 | 12:46 PM
BuckNeccid's Avatar
Sounds like your inside latch portion is out of adjustment, the one on the door frame, not the one on the door
Old Dec 25, 2009 | 11:48 AM
CoogarXR's Avatar
Junior Member
Welp, I moved the latch down as far as it would move (about 1/8"). And now it seems to work properly. We'll see if it lasts.
Thanks for the tip.
CoogarXR
Old Dec 25, 2009 | 04:39 PM
BuckNeccid's Avatar
Anytime. Actually, that sounds like you may have a seized backing plate inside there. It should move more than that. Basically it's about a 1/4 plate that's drilled for the striker, and that's maintained against the inside by a few flaps of metal folded over it, letting it slide up and down as well as in and out. Next time you have your inner panels off in the back, spray some good penetrant in there. If you have to adjust it again, you may have to pull those panels and spray it, then tap the striker gently to break it loose for it's full travel.
LW Hiway
Dec 28, 2013 09:08 AM
67gtxclone
May 31, 2010 05:33 PM
snkcraz
May 13, 2009 11:38 AM
Firemybird
Jul 27, 2008 09:08 PM
whowasat
Mar 17, 2007 09:12 PM
