69 fury gauge jumping to hot?
Old May 10, 2014 | 08:03 AM
69plymouthfury3's Avatar
My 1969 fury temperature is jumping to hot when you start it but then goes back to normal temp in a few seconds. It has done this a few times. Driving it will rise a little higher than normal but the thermostat kicks in and it goes down. Collant is full. Is this a sign I need a new thermostat? Is there a temperature sending unit somewhere that sends it to the gauge that could be the problem?
Old May 10, 2014 | 10:34 AM
yep, i'd replace that tstat... seems like it's sticking a tad. i'd probably replace the temp sender, while i was at it.
Old May 10, 2014 | 11:17 AM
Sounds more like the temp sending unit, on the top front of the motor
Old May 10, 2014 | 01:53 PM
Does the fuel gauge work? Does it do the same thing? If the fuel gauge does not work, it might be the gauge instrument regulator going bad.
Does it "act" like it is trying to overheat, IE puke antifreeze, etc?
If not I'd replace the gauge sending unit first.
labradorian70
Mar 29, 2015 05:41 AM
BruceJ
Oct 15, 2011 10:44 AM
Norskinder
Oct 15, 2011 08:09 AM
1973charger
Jun 4, 2009 11:40 AM
runninbird
Nov 25, 2007 12:44 PM
