fuse block location 1962 Dodge Custom 880
Old Aug 4, 2014 | 04:04 PM
62Dodge's Avatar
I cannot find the fuse block (holder) on my 1962 Dodge Custom 880. The owner's manual says it is on the bottom of the instrument panel but I just cannot find it. A picture or drawing would be great! The heater/AC blower will not work and I suspect it could be the 20 amp fuse the owner's manual mentions. Thanks! Bob
Old Aug 4, 2014 | 06:29 PM
The car might not have a "box" as such. I just took a quick look at the diagram over at "MyMopar" and it seems to suggest individual fuses strung in the wiring, and darn few of them at that
http://www.mymopar.com/downloads/1962/62Dodge880.JPG
Now, these diagrams can be somewhat simplified, not always correct, and don't always show all options and connectors, so take that for what it's worth...............
Old Aug 5, 2014 | 06:20 AM
62Furious's Avatar
In my 62 Plymouth the fuse block is under the dash just below the ash tray and radio. Hope this helps
Old Aug 9, 2014 | 04:58 PM
VALNUT's Avatar
IN my '64 880 it is located the same as 62Furious said. Under the dash, just below the ash tray. You've gotta stick your melon right up under to see it though.
Old Aug 16, 2014 | 09:42 AM
62Dodge's Avatar
After exhausting research I finally found out that there is no fuse box on a 1988 Dodge Custom 880. It is, as you suggested, a fuse in each circuit. I have checked both fuses coming from the blower switch and both are good. Am going to check the terminal block and see if something is going on there. Standing on my head and bending my neck past the allowable limit is getting to be a pain, so I think I will install an after-market switch at the bottom of the dash and hook it up to the new blower motor I got from O'Reilly's. Thanks!
Old Aug 16, 2014 | 09:44 AM
62Dodge's Avatar
For some crazy reason, Chrysler Corp. decided to not put a fuse block in the 1962 Dodge Custom 880, I finally found out! Thanks for the input, though. Appreciate it! Bob
Old Aug 16, 2014 | 09:46 AM
62Dodge's Avatar
In case you didn't see what I wrote Furious, there is no fuse block on a 1962 Dodge Custom 880, in spite of what the Service Manual said. Each circuit has it's individual fuse in the lines. Thanks for your input. Appreciate it. Bob
Old Aug 18, 2014 | 06:06 AM
62Furious's Avatar
that sounds like a crazy way to chase down fuses in a wiring harness
mrwillys
Jun 10, 2011 04:42 PM
ahaus
Mar 30, 2011 11:58 PM
highroller4321
Jun 30, 2010 08:01 PM
Kinger1421
Mar 3, 2009 10:05 AM
Mopar Guy in Delaware
Apr 3, 2008 06:30 PM
