Need some more help yall
Old 02-01-2009 | 07:07 PM
340CUDA's Avatar
Exclamation Need some more help yall
ok so this weekend i changed my valve covers (put the black wrinkle mopar covers on), changed the spark plugs, wires, distributor cap, rotor button, cleaned up the carburetor and put some oil stabilizer in for a ticking lifter...now she starts up great but once i put it in gear it'll start to sputter and lurch unless i go wide open throttle
i figured the plugs and wires were bad and it wasnt firing on all cylinders but i guess not, they needed replacin anyways...so if yall have any suggestions i would greatly appreciate it
btw the sputtering and lurching feels like when you blow a tranny hose in a newer vehicle if any of yall have experienced that
Old 02-01-2009 | 11:08 PM
Commando's Avatar
Did you change the gaskets when you replaced the valve covers? Sounds to me like a vacuum leak.
Does it run fine before you hit the accelerator, when the choke is engaged, or just when you shift?
Does the PCV valve and the breathers fit snugly and are hooked up?
Old 02-02-2009 | 04:27 AM
340CUDA's Avatar
the engine is a 71 340 out of a challenger, the plugs are champion copper plus, wires are x-acts 7mm (cheap but old wires were dry rotted)...forgot to mention that i had changed the valve covers a week before the plugs etc. and yes the gaskets are new, the only difference is that the breather hose is a little further back, and the engine sputters really bad when im accelerating in 1st and cuts back dramatically when in 2nd or higher...no problems when starting up or idleing
Old 02-02-2009 | 08:04 AM
could be a vacuum leak and/or timing.
What carb do you have? Did you adjust anything on it? how much cleaning did you do to it?
Old 02-02-2009 | 10:47 AM
Commando's Avatar
I had that happen to me when I last had the car running, would drive my automatic with both feet to keep it running.
I temporarily fixed the problem with spraying some carb cleaner into the pcv, and also hose clamps on both ends of the pcv hose to keep it attached.
Old 02-02-2009 | 11:04 AM
with the ticking lifter
are the lifters new?
Old 02-02-2009 | 12:28 PM
340CUDA's Avatar
ive been talkin to a few of my mechanic friends and theyre guessin vacuum leak as well, im gonna start by replacing all the hoses 1st because theyre dry-rotted
ive got a 4-bbl holley carb, not sure exactly what kind
and the lifters arent new, but theres one in there tickin up a storm
Old 02-02-2009 | 12:36 PM
340CUDA's Avatar
and how much of a pain would it be to put in a heater core?
Old 02-02-2009 | 03:21 PM
ticking lifter could be it going bad
thats what happened to me
what kind of oil are you running?
Old 02-02-2009 | 08:38 PM
340CUDA's Avatar
mobil 1 full synthetic - only to clean it up the old oil was sludgy, and i think ive got and bad head gasket bcuz it leaks pretty bad
how hard was it to fix your lifter?
Old 02-03-2009 | 02:53 PM
well, hopefully your problem with lifters is totally different with my problems with lifters
mine had to do with the no zinc in the oil, so my cam and lifters got wiped out, and they took a few of my berings with it
Old 02-03-2009 | 10:17 PM
340CUDA's Avatar
good lord i hope i aint got that problem
Old 02-04-2009 | 12:24 AM
340CUDA's Avatar
yeah that'd b great
i dont think i have the same problem that lifter was goin to town when i bought the car
Old 02-04-2009 | 06:10 PM
the motor could have been ran a while without zinc when you bought the car
the damage could have been done
Old 02-04-2009 | 08:26 PM
340CUDA's Avatar
fantastic
Old 02-08-2009 | 11:40 AM
340CUDA's Avatar
has anyone heard anything about the hose kits from hiperformancestore.com? They have a kit that repalces all the vacuum hoses and a few radiator hoses, etc...
Old 02-19-2009 | 12:14 PM
challenger's Avatar
Did you get your car up and running ??
BTYM
03-17-2014 01:08 PM
crash
02-22-2012 12:13 AM
Frank the Tank
12-14-2010 04:36 AM
MapleLeaf
12-27-2006 01:38 PM
