Vacuum Leak
Vacuum Leak
As some of yall may know ive got a vacuum leak, I was wondering if anyone knows anything about the hose kits on hiperformancestore.com?
There kits apparently replace all under hood vacuum lines, a few coolant lines, the line from the windshield washer pump, and the vacuum line to the heating and A/C controller.
most of the hoses are dry-rotted, so i was gonna replace em anyway
the carb gasket needs replacing
and i think ive got a bad head gasket because whenever i put the pedal down and park it after there is oil all on the left valve cover and alternator
Your going to have to figure out why you have oil coming out of your breather. You shouldn't have that at all. Even if you fix all your hoses and replace those gaskets, you could still have ol coming out.
sorry i think i miss led you, the breather isnt leaking, somewhere on the left side of the engine its leaking...the breather was moved back a couple of inches when i changed the valve covers and the hose is kinked up a little bit
hey yall, orry it took so long to reply...we put the smoke machine on the engine and couldnt find any leaks, messed with the timing (it was way off) and that seemed to do the trick but it still sputters a little every now and then, and i still havent done a compression test will soon though
does anyone know where i can get a breather cap with a pcv valve in it?
hey 67 when i changed oils to full synthetic i had a really bad problem if you remember as this some what started the zinc thingy on here but the FS oil was just flowing out my valve seals and was told by valvoline to change back to the VR1 oils as the FS oils have way to many cleaners in it and the VR1 has the right amount of additives in it to make it work for my engine and by the way it was like a faucet turned on with the oil pooring out my headers but the VR1 stoped all that
josehf34
36
12-16-2014 07:05 AM
