speedometer
I have a volare 1979. The speedometer cable is 60 inch. I wonder if the cable 80-inch willfit. Where I can buy. Thanks |
You came to the right place. First of all no body makes a direct replacment for our cars. Get an 80 inch one for a 1980 something truck. Then you have to replace your plastic adaptor with an older aluminum one and an older style gear. I did it and it works. Go here to order what you need.
http://www.transmissioncenter.net/sp...n_______va.htm get this cable. http://www.transmissioncenter.net/HPIM1719.JPG Part number 4360. Get this adaptor. http://www.transmissioncenter.net/HPIM1458.JPG Part number 13h. and then get one of these long shaft gears. They can tell you which one by tire size and rear gear ratio. http://www.transmissioncenter.org/HPIM1097.jpg |
If you have the original speedo adapter those gears will not fit. That is unless you use the older style adapter. I would check with a speedo repair shop.. They should be able to make a cable the length you need
A quick search turned up this http://www.speedometersolutions.com/...eter_cable.htm |
Originally Posted by TVLynn
(Post 89639)
also better with the older style since the gears are more available.
| All times are GMT -7. The time now is 11:28 PM. |
