needing a good work truck if work car dont fan out
Old 10-01-2008 | 04:16 PM
ef8340's Avatar
Senior Member
i'd like to get a 67-72 3/4 ton powerwagon camper special prefer a 69-70 ef8 green to match the swinger when i get it done so if anyone has any ideas especialy around here in georgia or south carolina let me know
Old 12-13-2008 | 05:55 AM
Make sure that if you do get a 4x4 that they front is not a closed knuckle design. If it is, the first thing to do is to swap it out for a mid 70 or later D44. Those closed knuckle 44s are junk. puls the swap will give you disc up front.
Old 12-13-2008 | 05:57 AM
Depending on the lug pattern of the axles in your truck, You can go with any 44 front. Doesn't matter if the axle is out of a 1/2 ton or 3/4 ton, they are all the same minus from the hubs out. The 1/2 tons are going to be either a 5 lug or a 6 lug, while the 3/4 tons are going tobe an 8 lug. There is no strength differnce though.
h340
24
12-18-2014 09:19 AM
Cazbah362
06-12-2011 01:05 AM
mytracy
12-29-2010 08:20 PM
Quick Reply: needing a good work truck if work car dont fan out
