1999 Ram 3500 Quad Cab 2wd Cummins PCM pinout diagram
Old 05-22-2018, 01:58 PM
Drag Pak's Avatar
1999 Dodge Ram 3500 Quad Cab - 2wd Cummins - automatic transmission.
I am having erratic speedometer issues and need the PCM pinout diagram/schematic to check the wiring.
Dealership won't give it to me. Say it's proprietary.
Both speed sensors check ok.
Any help greatly appreciated.
Old 05-22-2018, 07:06 PM
Did you check the speedo sensor on the diff
Old 05-22-2018, 08:22 PM
Drag Pak's Avatar
Yes, the rear diff sensor has the correct resistance and the pigtail has 4.9V and a good ground respectively.
The transmission output speed sensor pigtail reads 2.63V on both sides, (I believe it should be a similar 4.9ish Volts and a good ground respectively)so I feel there is an issue somewhere in there that needs to be checked for the full length of this sensor's wiring.
Old 05-22-2018, 08:40 PM
I'll look in my stuff at the shop tomorrow and see if I have them.. Please bump this up if I forget about it in the morning... I'm getting old...lol
Old 05-23-2018, 05:46 AM
No Specific Code? Like a P0720 or P0500 or Check engine light ?
Old 05-23-2018, 08:10 AM
Boy that must be a well kept secrete... I dont have anything in my stuff.
Old 05-23-2018, 08:16 AM
Drag Pak's Avatar
There are no warning lights coming up. I tried the ignition switch(on/off/on/off/on) to flash the codes but it doesn't work. Apparently 1999 is not the same as previous years for flashing codes.
Thanks Bob, any information greatly appreciated.
Old 05-23-2018, 01:32 PM
True, Not the same. I think you need a DRBIII to look at the PCM / TCM / ECM and or the CAN BUSS.
I looked over at the iATN site. But looks like the help is all over the place !!
Old 05-23-2018, 04:04 PM
Drag Pak's Avatar
Bob
After many hours, I found this site with good wiring stuff - https://mopar1973man.com/cummins/art...ing-maps-r469/
and a 2001 pdf service manual that gives the pinouts.
Can't believe how stingy the dealership's are forced to be.
Many Thanks for your time !!
Peter
Old 05-23-2018, 09:14 PM
Your welcome Pete.... No problem. Wish I could have found more.
My guess is that the problem is going to be the cluster OR PCM to TCM Communication problem.
But at least with the pin out you was looking for, you could of at least ruled out a broken wire or a shorted one with out too much fuss.
I do have alldata and onDemand... Let me know if I can help you with anything else.
Keep us posted on what you find...
Thanks
Bob
Old 05-24-2018, 01:26 PM
Old 05-24-2018, 01:59 PM
I did find some other pin out info. I didn't have time to look for specifics....
http://connectors.dcctools.com/home.htm
Old 06-28-2019, 07:37 AM
Drag Pak !!!! Hope you are well !!!! Did you get your truck sorted out?
How is the old Hot Rod Doing !!!!
Old 04-09-2020, 02:54 PM
98.08cummins's Avatar
Where did you find correct voltage and resistance trying to diagnose my speedo problem.
matt1967
05-10-2018 09:14 AM
rgengelking
11-21-2015 07:56 AM
Jentlee2
10-23-2015 07:22 PM
Jbs6891
11-12-2014 05:20 PM
scotts74birds
05-17-2010 06:50 PM
Quick Reply: 1999 Ram 3500 Quad Cab 2wd Cummins PCM pinout diagram
