318 magnum stroker
Guest
Posts: n/a
318 magnum stroker
i have a 318 magnum and a 360 magnum both out of 4x4 pickups a 94 and 95. someone told me i could take the crank and heads off the 360 and put them on the 318 to create a stroker 318. is this possible with out alot of time and money invested?
You can but you should throw in a performance camshaft, larger injectors and have the computer retuned to get the most out of it. While your at it, get rid of the dome style intake for a FI intake with actual runners. You will spend some money on machine work and parts.
How much are you limiting this project to? What are you going to be putting the motor into and what will the vehicle be used for?
yes you can put a 360 crank in a 318 but you need to turn the main bearing journals down to the size of the 318. also it might be a problem finding pistons. you could mill the top of a set of trw's I guess. The heads will bolt on no problem.
