98 Ram 5.9 Random Code 0304
Old Jan 27, 2009 | 02:50 PM
Polaradude's Avatar
Maybe you have tried this but pull the positive terminal on your battery and let it sit with no power to the brain and maybe it will clear the code.
Old Jan 27, 2009 | 03:53 PM
Polaradude's Avatar
Wow, thats weird man, are you running a static strip ? I am guessing now, maybe static elec. is putting up the ghost code.
Old Jan 28, 2009 | 03:47 AM
With the code reader can you watch sensors? If so, watch the screen that shows the fire counter for the spark plugs. There should be a counter for each cylinder.
What plugs did you install when you swapped them? Who's gas do you pump into your truck? Do you change who you go to for gas or do you stay with the same station? Have you checked the plentum pan for leaks? What did the spark plug look like when you pulled it? Are the plug wires resting on anything?
I know its a lot of questions.
Old Jan 28, 2009 | 06:48 AM
The plentum gasket could definitely be the cause of oil loss and the random misfire depending on how much oil is loss and when. All you have to do is look down into the throttle body at the sides of the pan. If you see the gasket and/or oil, then the pan and gasket needs to be replaced.
The rocker arms are not adjustable to my knowledge on the magnum motors. They just get bolted down to the heads.
Old Jan 29, 2009 | 12:14 PM
Or upgrade the heads.....
Old Jan 29, 2009 | 01:02 PM
good luck with whatever you do
Old Feb 3, 2009 | 01:28 PM
watch for white smoke as that could be a coolant leak. Also, just go over everything and make sure that they reinstalled everything accordingly. I know that the dealership should but you can never be too safe. check your fluid levels after a day or so also and top off where needed.
BTYM
Mar 8, 2014 08:22 PM
jbwinkle
Oct 12, 2012 02:46 AM
JETBLU
Sep 14, 2011 07:06 PM
scott2683
Jun 27, 2010 08:22 PM
Moparknighthawk
Sep 2, 2008 08:35 PM
