Ram exhaust
Old Oct 8, 2008 | 07:04 PM
plymouthrr1985's Avatar
Ram exhaust
The exhaust on my 1997 Ram 4x4 is rusty and needing to be replaced. I was thinking of going with an aftermarket hi-flo cat. Is this a good idea or should i get an oem from the local dealership??
Old Oct 15, 2008 | 06:17 PM
challenger's Avatar
your on the right path as i would also go with an after market exhaust kit and not a dealer kit , try and go with the 3" kit to unleash some more power unless you live in a state where you need to keep it under control
Old Oct 16, 2008 | 03:28 AM
A high flow cat would help out greatly, just make sure to get the right size cat. Another way to help with the flow is to take the Y-pipe to a local exahust shot and have them bend you a new one with smooth bends.
I'd got with a kit that has smooth bends and install a hooker max flow muffler. they flow twice as much as the flowmasters do.
Old Oct 16, 2008 | 07:31 PM
I was thinking of going with 3" from the manifolds back.
Old Oct 17, 2008 | 03:16 AM
If you do go 3" back then you will lose some backpressure and will lose some low end power. I'd run the standard back to the cat and from the cat back run 3" single if you want.
t/s1148
Apr 29, 2015 11:09 AM
Brian Grosshans
Jul 23, 2013 10:29 AM
bddanford
Aug 18, 2009 12:20 PM
J Dog
Jun 26, 2008 07:10 AM
steelyblue
Sep 12, 2007 06:48 PM
