sync
Old Aug 28, 2020 | 08:14 AM
osok6's Avatar
sync
96 318 ci
intermitent loss of sync between ckp and cmp after reaching operating temp with high ambient temp
the hotter it is outside the worse it is. sensors check out as ok
faulty ground???
Old Aug 29, 2020 | 05:17 AM
Whats the Fault Code or Codes ?
Old Aug 29, 2020 | 10:15 AM
osok6's Avatar
no codes
Old Aug 29, 2020 | 06:19 PM
You should have got a P1391 Code with a check engine light on?
How did you come up with the issue?
However>>>> If the sensor are checking out good>>>> You have a bad connection or wire Breaking down when hot>>> Or>>> A faulty PCM.
I was going to say the ring was loose, But if its only dong it when it hot? I would go with whats mentioned above...
Good Luck
1stdodge
Jun 24, 2020 01:50 PM
MilesP
Jul 5, 2013 09:19 PM
74charger
Oct 26, 2011 05:31 PM
sendust
Aug 24, 2011 12:48 PM
DartConvertible
Mar 17, 2008 05:22 PM
