TBI to Magnum help
Old Oct 24, 2011 | 04:25 PM
91d150's Avatar
TBI to Magnum help
the engine is a 1994 5.9 magnum 70,000miles
truck its going into is a 1991 D150 2wd A904 automatic.
what will i need to change to make this swap go smooth? The engine came with a flywheel with the weights so that problem is solved
Old Oct 25, 2011 | 08:33 AM
This should work as the trans should be an RH not RE, aslong as you have the Powertrain Control Module (PCM). Transmission mount is different and further back with a shorter driveshaft required.
I would suggest getting wiring diagrams for both to compare hook up points.
I was assuming your swapping engine and trans, maybe I got this wrong. Are you hooking the 5.9 to the 904 3 speed?
If you are you'll need to notch the bellhousing for the crankshaft sensor.
Old Oct 27, 2011 | 04:32 PM
91d150's Avatar
its just a engine swap. keepin the 904. plus i'm going to buy the edelbrock magnum 4 barrel intake and put a holley on it. never liked fuel injection anyway. going to bessler's you pull and save saturday and buying all the front accessories, motor mounts, dizzy. anything else i should pick up?
atowncris
Nov 3, 2009 08:26 AM
silvermopar
Sep 9, 2009 01:28 AM
bennersaw
Feb 18, 2009 05:48 PM
73_Mopar_Muscle
Jan 30, 2008 10:57 AM
tbreaden
Jan 20, 2008 02:18 AM
