4 cyl dying
Old Aug 17, 2010 | 08:37 AM
buddyleewv's Avatar
4 cyl dying
Hi all and thanks in advance for any info.
I have a 1998 Dakota 2wd regular cab 5 speed with a 2.5 4 cyl that has 191,000 from the noises its making and the total loss of power going up hill it think its about to die. I'm curious when it dies could i put in a 318 motor or at least a 6cyl.
thanks,
James
Old Aug 17, 2010 | 08:58 AM
You probably have either an ax15 or an nv3500 tranny. Both are good enough for the 239ci, 3.9L V6. They (the trannys) are not going to be strong enough for a V8 though..... well, they would work, just not last that long.
EDIT: Your truck probably has an AX5, NOT the AX15 or NV3500. The 2.5L 4 cylinders all came this way (truck and jeep). The AX15 and NV3500 is found behind the 6 cylinder motors.
Old Aug 17, 2010 | 09:28 AM
1966sportfury's Avatar
A.K.A Bob Dodge
so that tranny will bolt up to a SB? then if he sticks a V8 in there he could take it easy till he got a 904 or a 727?
Old Aug 17, 2010 | 09:56 AM
The bell housing bolt patterns are the same between the 3.9, 5.2 and 5.9. I was mistaken about the tranny though. It will most likely be an AX5 which is the little brother to the AX15. I wouldn't trust the AX5 behind anything larger than a 4 cylinder. If you want a larger motor, swap it in with a larger tranny. 3.9/nv3500 should be pretty cheap, even if it's out of a donor truck.
Old Aug 17, 2010 | 07:56 PM
buddyleewv's Avatar
Thanks for the info. The reason I was wanting to keep the tranny is because it's a 5 speed when I bought the truck the only thing I could find with a v6 or v8 came with automatics. I have ( knock on wood ) been very lucky with my transmission I just replaced my clutch at 185,000 miles and I've heard nothing but horror stories about the automatic transmissions in the Dakotas. I was just wanting a little more umph under the hood
Old Aug 17, 2010 | 08:23 PM
Barfly's Avatar
Here is a pic under the hood of my '90 Dakota with a 340 / 727 combo.
Good Running Motor, just needs the right guy to tune her in
Don't forget, you'll need to look at your rear end gearing..... it's been a long
drug out project for me. But we finally got it.
Good Luck with your project!
85Dodge440
Nov 2, 2013 04:33 PM
grease-monkey
Oct 23, 2011 01:16 PM
1966sportfury
May 8, 2010 08:17 AM
ariesfs
Dec 31, 2008 03:14 PM
Mixmastermerrill
Oct 20, 2008 09:22 PM
