Engine Installed
Old 11-23-2010 | 07:19 PM
Engine Installed
engine guy just left my garage... Engine is bolted in the car..... Just sitting there but it is installed... Now to get a good nights rest and hit it hard tomorrow... Hopefully the flex plate, tranny and drive shaft tomorrow.. That will have most of the underside done..... Will try to get a picture or two tomorrow......
Old 11-24-2010 | 03:21 AM
It's tomorrow! WHERE ARE THE PICTURES!
Old 11-24-2010 | 05:37 AM
Polaradude's Avatar
LMAO....X2
Old 11-24-2010 | 06:02 AM
Calm down and just wait.... I've just gotten out and will get them soon... Just don't get your panties in a WAD !!!!!!!!! Or just get over it!!!!!! LMFAO....
Old 11-24-2010 | 09:14 AM
Yeh, Its Got A Hemi
That is the best title I can think of for these pictures... Whatch think????
Attached Thumbnails Engine Installed-yeh-its-got-hemi.jpg   Engine Installed-yeh-its-got-hemi2.jpg   Engine Installed-yeh-its-got-hemi3.jpg
Old 11-24-2010 | 03:04 PM
Polaradude's Avatar
Now that's what I am talking about baby...f**cking sweet.
Old 11-24-2010 | 05:11 PM
samuelcosmo76's Avatar
JEALOUS.
Old 11-24-2010 | 07:04 PM
62Furious's Avatar
it actually does have a hemi with room under the hood
Old 11-26-2010 | 05:00 AM
Had a pretty good day yesterday even though I only worked half a day... Got the tranny, converter, flex plate and drive shaft installed. But, it all has to come back out... Just the normal first time installed and need to change this n that... Shifter linkage is out of adjustment. One bolt on the tranny bellhousing isn't threading up just right so will have to run a tap in the back of the block... Carbon Fiber tranny shield is covering one of the tranny cooler line fittings.. Have to trim that... Just the normal build things that have to be done.. I have learned one thing though. Its much easier with a lift and a tall tranny jack than laying on your back with your tranny on a floor jack and a block of wood!!!!!!
Old 11-26-2010 | 06:21 PM
From the Bottomside
Took a couple of shots from the bottomside as the build progresses.. About done down under.. Or at least I hope so!!!!
Attached Thumbnails Engine Installed-bottomsideworkzone.jpg   Engine Installed-bottomsideworkzone3.jpg   Engine Installed-bottomsideworkzone5.jpg   Engine Installed-bottomsideworkzone2.jpg
Old 11-27-2010 | 05:02 AM
Mack,
Everything looks awesome! Where is the panhard bar/track bar for the rear axle though? Is it mounted on the back side of it?
Old 11-27-2010 | 06:38 AM
Mack,
Tim, you are correct... If you look at the yellow coil spring and then look very hard you can see the joint that is mounted to the axel housing. Its hard to see but its there.... It then travels behind the rear to the other attachment point on the other side of the car..... Will try to get a shot of it today..... Mack
scott2683
04-05-2011 09:37 AM
mytracy
01-29-2011 07:43 AM
rexus31
06-05-2010 04:19 AM
rexus31
10-26-2009 07:39 AM
azzkikr
03-03-2008 08:45 PM
Quick Reply: Engine Installed
