Engine swap and fit
Old Feb 2, 2022 | 02:09 AM
RU32's Avatar
Question Engine swap and fit
1st question;
I have a1969 AMC Javelin and would like swap the engine for a.
375hp 345ci Crate Hemi or a
485hp 392 Crate Hemi
2nd question;
the engine that is in the Javelin is the 290.from what I have read the the 290 block was used as the main block for most engine builds. I bored the cylinders 30 over and replaced the 290 head and swapped them out for the 390 heads. Is there anything I should keep an eye out for. The car is not running at this time. The last time I worked on it was 28 years ago. Before I left for the Army. I rebuilt the eng, now I will have to rebuild it again.
Old Feb 2, 2022 | 08:06 AM
Valve pocket... The difference between those heads are. They just have a slightly larger exhaust valve... Heads are close to the same other than that....
RU32
Feb 1, 2022 07:39 AM
RU32
RU32
Feb 1, 2022 07:38 AM
Stinky211
Apr 22, 2019 12:05 PM
bigmoss
Mar 25, 2019 07:17 AM
