1991 Wrangler YJ right front axle seal
I have a 1991 Jeep Wrangler Renegade, 6cyl, 5 spd. I have a right (passenger side) front axle leaking. How long does this normally take to replace (at a dealer and if I try it on my own? And would I need to replace anything else at the same time? Money is a issue. Thanks
Bob, Is that for both front axle seals, pinon seal, disconnect axle gasket, diff housing gasket and oil. $400.00? Do the front axle u joints and the upper/lower ball joints ever go bad? I've got around 180,000 (easy) miles on this jeep. The only thing I do know is the real output seal on the transfer case is leaking and the front right axle seal leaking. I really like this jeep had it sense new. I'm kind of in the middle of selling it or fixing up. I just don't want to spend to much then find out it's not worth it? All information is greatly appreciated.
MoparLover3
Feb 17, 2015 02:37 PM
