1970 Cuda temp gauge inop
Old Jul 13, 2009 | 07:36 PM
elsewhere's Avatar
Junior Member
Does the gas gauge work? There is a voltage limiter in between the fuel and Temperature gauge. It is a small silver rectangular box. It reduces the 12 volts down to 5 volts for the temp and gas gauge. One wire on the temp gauge goes to the water temp sending unit and the other wire goes to the voltage limiter. If you remove and ground the sending unit wire the temp gauge will peg out the the Hot side meaning that the sending unit is bad.
Old Jul 13, 2009 | 08:31 PM
theomahamoparguy's Avatar
x3. {mopar action website has an article about mopar gauges}
Old Sep 24, 2009 | 06:14 PM
koondawg_74 roadrunner's Avatar
wow im having the same problem with my roadrunner. Neither the temperature or pressure gauge work
Old Jun 1, 2011 | 04:29 PM
fury360's Avatar
Hi all,
I am having the same problem, only intermittent, sometimes the TEMP gauge works, sometimes no?? Any ideas? '73 Plymouth furyIII, 360. The wire itself is in ok shape. I cleaned the little end connector, squeezed it closed as to have a nice snug fit. No luck.
67hemidart
May 21, 2012 05:29 PM
Norskinder
Oct 15, 2011 08:09 AM
sendust
Aug 24, 2011 12:48 PM
belve2
Mar 9, 2010 07:20 AM
Airkiller
Sep 21, 2009 07:38 PM
