'67 cuda 340 1/4 mi time
Old Apr 29, 2010 | 04:51 PM
ryan's Avatar
Talking '67 cuda 340 1/4 mi time
hi folks this is my setup which i am happy with but wouldn't mind knocking a liittle time off. eng. is .030 over trw 10.5 stl crank arp rod bolts balanced. iron heads from hughes supposed to flow as edel rpm heads 2.02 1.625 valves hyd 238/244 .535/.540 cam roller rockers airgap rpm intake port matched 750 dbl pumper out of the box no jet change. tti headers 3in exh to mufflers 2.5 out the back. i uncap the mufflers @ the track. 727 manual valve body 3700 stall 4.30 gear. 26" slicks. i know i could get a better et with a higher stall but i do drive this on the street not like a daily driver but rather for fun best et is 12.13@114 mph. fast enough to surprize some bigblocks. i am satisfied with this just wondering if i could shave off a little with some changes. i don't like nitrous. with a 3200 stall my et was 13.00@115or6. 60 ft was slow
Old May 7, 2010 | 10:28 PM
SCAMP TRAMP's Avatar
My 2 cents .... put the car on a diet, if it dont need it rip it out - set of real skinny's up front and go with a 4200 stall and bump your gear up to a 4.56 or 4.88 ..... you'll notice a diffrence
Old May 9, 2010 | 12:44 AM
theomahamoparguy's Avatar
999 trans would be lighter, less reciprocating weight. Just an idea
Old May 11, 2010 | 11:54 AM
ryan's Avatar
im running a 4.30 gear with 26in slicks so im just about maxed out crossing the line at 6600 rpm. i think a 4200 stall would definately get me a faster time i might try that also i was thinking of a fiberglass hood a little weight loss
Old May 15, 2010 | 01:28 PM
This place makes good stuff I've gotten a few things from them, and all were top notch workmanship - they have everything for your 67 - keep your gear, play with the stall and throw some glass on you'll go faster
http://www.usbodysource.com/
Old May 26, 2010 | 01:32 PM
ryan's Avatar
thanks guys when i break the 12 sec mark im going to need a roll cage anyone know of a good kit i dont have a tube bender but i am a welder.
Old May 26, 2010 | 02:17 PM
blue 68 gts's Avatar
With a 26" tire, you should be at like 4:10s or 3:91s..
And you don't need a roll cage until you hit 11.49 or faster.
I have a 27" tire on my car with 3:55s, when i put my 26" tires on, i ran a half tenth quicker then my 27" tires, but less miles per hour.
Old Jun 2, 2010 | 12:46 PM
ryan's Avatar
blue 68 gts you have a big block in your car the gearing really depends on where the powerband is in your engine mine makes good power from 4 thru 7000 rpm. i will look into the rollcage i thought it was 11.99. you don't by chance have a dad that runs a yellow 68 gts.
Old Jun 3, 2010 | 06:15 PM
Rollcage time was changed a few years ago to 11.49.
And yes, thats my dad.. how'd you know?
Old Jun 12, 2010 | 12:32 PM
ryan's Avatar
i bought a green 69 gt from him i saw you and your dad a year or two ago at one of the mopar events. it was the first time i saw your car its a nice ride. im planning on going to the event early august maybe i'll see you guys there.
cudaneil
Jan 5, 2013 11:27 AM
straightener
Oct 13, 2012 05:42 AM
cudaracer
Jun 19, 2010 10:21 AM
'cudafreak
May 10, 2009 08:21 PM
rabys
Mar 22, 2008 11:37 AM
