67 cuda convertible 273 commando
Old May 4, 2009 | 11:07 AM
sammywhiteass's Avatar
Exclamation 67 cuda convertible 273 commando
Hey guys. i have a huge number of questions. i have been overseas in iraq for a long time and i am back in the states now. i picked up a 67 barracuda convertible with the 273 commando 4 speed before i left. I'm not sure what rear end is in itthough. havent torn it apart yet. What can i do to make the fish swim faster. I know the 318, 360 and the 273 have some interchangeable parts. i want to keep the 273 in the car though. i was wondering if the 700 cfm carb from edelbroch would help out. thank you to whoever helps me.
Old May 4, 2009 | 12:10 PM
Thank you very much for your support. it feels good to be back home. i would like to keep it a little stock to keep the value up.
Old May 4, 2009 | 03:16 PM
if the back piece is welded on the rear end, it is a 8 3/4
Old May 4, 2009 | 06:22 PM
thank you for the feed back. so if the third member is welded, it is an 8 3/4. but if it is just bolted up there it is a 9 1/4
Old May 5, 2009 | 01:52 PM
is it most likely a 8 1/4 like hypermite said
a pic would help
Old May 5, 2009 | 03:54 PM
Commando's Avatar
9 1/4 were not put in A bodies. If there are 10 bolts its an 8 1/4 and I think there are 9 bolts on the 7 1/4.
Old May 5, 2009 | 05:19 PM
Red Devil's Avatar
Little Demon
welcome home and thank you so much for your service, we appreciate it more than words can say.
I totally agree with keeping it #s matching, hang around here long enough and you will see that I say that a lot Everyone on here has good advice and the all know their stuff really well. All the suggestions these fellas have said are good places to start, just let us know what we can help you with
Old May 13, 2009 | 12:41 PM
chlngr1970's Avatar
+1000 on the welcome home and thank you for your service. Here are a couple pictures of the rear ends being talked about. The 8.75 is like the ford 9" with the removable center section from the front. The 8.25 is common with later model cars with the 318. If your Barracuda came with the 273 4bbl carb, it might have the 8.75. If that is the case, it can take almost anything a small block can throw at it. The second pic is the 8.25, and can also take quite a pounding. If you have the 7.25, I would look for a replacement rear end to go with your motor.
As to the motor, bumping up to a 360, while still looking fairly stock, would give you a tremendous increase in power potential. If you keep the 273, go with a good build, 9.5 comp, 272ish durration .420-.450 lift, and Edelbrock performer intake, and a 500 CFM carb, small tube headers with 2"-2.25" pipe and Flomasters or Dynomax mufflers, or even some Flomaster knock offs will work on a budget. A good clutch and n A833. For street duty, I would stay in the 3.23 to 3.55 rear end ratio. Much more than that gets challenging for street use.
Hope this helps
j
Attached Thumbnails 67 cuda convertible 273 commando-875-rear.jpg   67 cuda convertible 273 commando-axle_825.jpg
Old May 28, 2009 | 02:10 PM
all i can say is thank you all very much. I finally got my YEAR1 catalog and have started my little wish list. I didnt know all the different things i could do. I'v been dealing with hummers for the last few years.lol
Old May 28, 2009 | 02:48 PM
scotts74birds's Avatar
Good catalog. Year one has been able to compile alot of stuff, from many sources into 1 place. But it comes at a price...namely the price! Once you find what is available out there, you can search, and usually find it cheaper elsewhere. Everyone has the right to make a buck, but nothing wrong with shopping around.
Old Jul 9, 2009 | 07:20 PM
Here is another qeston; shoudi convert to an elctonic fue pump and how without flooding the carb and should i get an electronic ignition an if s which one?
Old Jul 10, 2009 | 05:33 PM
Re; fuel pump. No need to for your application. You will not need that much fuel with your combo, save your money.
Old Jul 16, 2009 | 05:47 PM
i was wondering. How much would a complete engine rebuild cost and should i build my cylinder heads formyself and what do the numbers mean for the lift, dur, and comp?? i have rea abut the 273 with over 450 horse power and 500 torque. thats what iwant how should i decid what to put in my car and what does the cylinder diameter have to do with compression if there is only a dfferencefrom3.655 to 3.665 and 3.645
Old Aug 5, 2009 | 12:00 PM
all right. bad news. I have rust inside of my valves somehow. I pulled the heads and there it was. I was wondering why it didnt turn over and nothing. I am soaking the valves right now with marvel mystery just hoping to break up the rust. and oh yea, i have an 8 3/4 rear end.
Old Feb 21, 2010 | 08:04 PM
68barracuda273's Avatar
Junior Member
Cool 68barracuda273
i got a 68 barracuda fast back as my first car and my first car project from my friends dad because my friend and i helped his dad get his 66 charger with its new 440 running and he gave my frind a 66 formula s barracuda to fix up, so he wanted to get me a car to fix up and it was almost a 68 notchback cuda but couldn't so he gave me his parts car for his 67 formula s cuda and gave me a 273 commando and i was doing some research along time ago and found out that a stock 273 commando will out perform a stock 360 so stay with the 273 commando. if you want more power find a stroker kit for it or at least cam it and get some high performance edelbrok heads for it and have the crank shaft balanced, a high rise intake with a 600 cfm carb, put some hooker headers super comps with cutoffs right behind the headers and flowmasters at the back. that would be an awesome set up.
Old Mar 11, 2010 | 12:13 AM
Well the motor is out now and on they way to get built the propper wayi have a guy in vegas who is doing the work. I wish i could learn the trade. Ive got a low pro intake and some cams so far and an msd. pretty excited.
Old Mar 11, 2010 | 01:10 AM
1966sportfury's Avatar
A.K.A Bob Dodge
oh so true..my girl has a 66 mustang that was her moms and she wants to rebuild and make it look nice. well stripping the paint i found the whole driver side rear quater was re-shaped with body filler. from tail lights to door. i logged on to year1 and found skins for $59.00 blew me away. but they wanted $209.00 to ship them. i found another web site that wanted a little bit more. (of the same guage) but bought and shipped for a total of $99.99. so spend an hour or so surfing the web. a little time can save hundreds of $$
Old Mar 13, 2011 | 10:40 PM
Well I have been away from this for a while and have made some pretty amazing progress. The motor has been completely re-built from the bottom up and has 370 horse. I am starting work on the body and finding out how much this poor car has been through. hopefully I will be able to post some more pics. and another question I have is where to buy a straight gate or v gate shifter for a borg warner t-10
Attached Thumbnails 67 cuda convertible 273 commando-cimg1581.jpg   67 cuda convertible 273 commando-cimg1584.jpg   67 cuda convertible 273 commando-cimg1604.jpg   67 cuda convertible 273 commando-cimg1605.jpg   67 cuda convertible 273 commando-cimg1578.jpg
Old Mar 25, 2012 | 04:50 AM
dartcuda's Avatar
Smile 67 cuda convertible 273 commando
The best thing to do is take a picture the back of the rear housing.My car was a 67 273 hipo and it had a 7 1/4 rearI din't think they had 8 1/4 rears in 67.8 1/4 was 1972 and later.I was racing a mustang and you know what happend to the 7 1/4 rear. Mark
Old Mar 25, 2012 | 01:42 PM
How did you arrive at 370 HP ?? Stock 273 was a DOG. My 66 Coronnet came with a 273 trashed it for a 361 B motor, this would have been back in mid 70's. Also had a 65 barracuda with a 273 auto
dodgebros
Jun 23, 2016 10:57 AM
solm96@me.com
Jul 10, 2010 08:35 PM
bcuda67
Cuda Specific Discussion
Jul 25, 2009 11:16 AM
crmzendrgone
Mar 12, 2009 05:48 PM
rusjean
Feb 15, 2009 03:32 PM
