damn wiring need help
Guest
Posts: n/a
ok so i was driving my cuda around and it just lost all electrical. I got it home found that power wire coming from the battery to the terminal block blew the fusable link. Replaced that now I have power everywhere but it still wont even crank via keying it. I can jump the solinoid but still no spark. Its got 10 volts to the coil. Any help would be great.
Guest
Posts: n/a
You didn't specify what year your car is but you can get schematics for free at:
http://www.mymopar.com/wiringdiagrams.htm
Where to start with your limited information... you may have a problem in the dash area. Check your ammeter connections and/or bulkhead connections for opens. Also check your neutral safety switch for correct operation if your starter is not working. I can get more specific if you define the problem better.
