ANYBODY RUNNING DRAG RADIALS?
Old Oct 11, 2009 | 01:40 AM
toad490's Avatar
If your running drag radials how do you like them and what have you got them on?
I bought a pair of 315/60/15s for my Cuda and I'm wondering how they would be at the track. I hope I'll be making around 750hp, the car should be around 3600lbs and I've got a 4500rpm stall convertor.
Old Oct 11, 2009 | 04:48 PM
two friends of mine use them
one set is on a 9 second car, the other will be on a 11.5 car
the 9 second car guy really likes them
Old Oct 11, 2009 | 07:05 PM
dynosteve's Avatar
i've run them on several cars and recently on my 9sec challenger just dont go under 15psi
Old Oct 19, 2009 | 08:42 AM
1 Bad Mirada's Avatar
Administrator
i run hoosier DRs on everything...quick time pro, 26x11.5x15 on the truck, demon, and mirada...i love them, and pull great short times, for my ETs.
Old Oct 19, 2009 | 10:53 AM
HEY 1BM! How have ya been?
Old Oct 19, 2009 | 03:45 PM
Administrator
not bad...i was dealing with some blood pressure issues for a while, but im all fixed up now. we had an incredibly busy past few months. we had three weddings, two of which i was the best man...one was in miami, one in pittsburgh...then we took the mirada and demon to the mopar world finals in norwalk...then weve been dealing with horse shows and such. ill make a thread about the racing rather than jacking this thread!
Old Oct 21, 2009 | 03:50 PM
good to have ya back
Old Oct 31, 2009 | 02:21 AM
toad490's Avatar
Thanks Guys, I won't be going any faster than those times, so they should do me.
Old Dec 1, 2009 | 05:25 PM
ykf7b0's Avatar
I am assuming you are referring to dot drag radials. If your are putting that much horsepower to the pavement then your suspension is definately going to have to be in fine tune, otherwise, you will be needing 11 or 12 inch drag racing only slicks to hook that monster up. I've been there. I had dot drag radials on my '69 roadrunner and was making at that time around 434 hp at the rear wheels and close to 600 hp on the bottle. I was running 10 inch Hoosier Quick Time Pro's and they seldom hooked and then I opted for 11.5 Micky Thompson ET Drag's and hooked 98% of the time. My setup included the subframes tied, hemi b body leaf springs, drag shocks (rear), adjustable shocks (front) and set at 90-10 for faster front end rise, front sway bar removed, battery relocated to right rear trunk space, and adjustable pinion snubber set close to floor pan to aid in planting those rear tires. I am not a fan of the dot tires for track performance because I just couldn't get them to bite consistently with my setup.
Old Dec 13, 2009 | 03:20 AM
toad490's Avatar
Yes there're DOT, I do have Caltracs and monoleaf springs with Rancho 9000 shocks for it but I'm a little worried. I don't want to put the thing in the wall or worse somebody else. If they give me any trouble at all I'll get slicks and anothe pair of wheels.
deadkelly
Jun 22, 2014 12:50 AM
ctreser
Sep 20, 2013 08:24 PM
69POLARA383
May 24, 2012 07:37 AM
Chaotic Symphony
May 20, 2012 12:57 PM
blkse#75
Jul 20, 2007 04:42 AM
