Big Block Heads?
Old Jul 19, 2010 | 11:12 PM
YellowDodge67's Avatar
Junior Member
Big Block Heads?
Which heads would provide the best bang for the buck and would be best in the long run for a street motor that will eventually be built further (600+hp)? Edelbrock aluminum heads, Mopar Performance aluminum heads, stock heads with machine work, or the aluminum heads on 440source.com?
http://www.summitracing.com/search/P...r+heads&page=1
http://store.440source.com/Stealth-A...info/200-1055/
Old Jul 20, 2010 | 12:06 AM
1966sportfury's Avatar
A.K.A Bob Dodge
either the edels, or 440 source, the mopar heads have alot of shrouding, and would reguire quite a bit of deshrouding to make them flow well,
Old Jul 31, 2010 | 05:24 AM
rexus31's Avatar
Be sure to check the head gasket mating on the Stealth's. There have been fitment issues causing the head gasket to overhang in the chamber.
Old Sep 28, 2010 | 05:45 AM
drgrcr74's Avatar
I really like the 440 source heads. We used a set on the race car and they worked really nice. They were a good alternative to the Indy brand heads, as we were boycotting Indy.
Old Jan 6, 2011 | 07:34 AM
Mistermopar's Avatar
Why were you boycotting Indy?
Randy
Old Sep 20, 2011 | 08:38 PM
383man's Avatar
Fury-ous
You said you may want to go even with more hp later ? Well I use the Indy EZ heads as they were only a couple hundred dollars more and they have much more to work with then any of the other heads you mention hear. The EZ heads can support up to 800 hp. Ron
Hot Rod Dave
Feb 2, 2014 09:22 AM
pipdog69
Mar 13, 2012 11:01 PM
440truck
Apr 22, 2010 07:17 PM
68satellite
May 23, 2009 05:33 AM
mahd
Apr 2, 2009 09:05 AM
