good cams
wat cams would b pretty good for a 440 engine i just bought i was lookin at the comp cams but i dnt know the difference in all of them
call comp cams up and explain exactly what you have and what your looking for and they will steer you in the right direction:)
Originally Posted by GEORGE68HEMIRR
(Post 36703)
it all depends on what you want to do with the car
drag racing? street/strip? |
I used Dwayne Porter at "Porter Racing Heads" and had him custom grind me a solid flat tappet cam. It works great as he is very good. Every car I see with his cams run great. You just give him your eng specs and he will spec out a cam for you. And the price was not bad at all. Ron
Figure out where you want the power, whether or not you care if it has street manners, weight of vehicle, gearing, etc., what else you want or don't want to do to the engine/ tranny, then you can pick your cam.
I wouldn't use a comp cam either. Just my opinion though. |
i jst installed a comp cams kit very satisfied :hello::hello: https://moparforums.com/forums/image...ies/hello2.gif
hughes engines has some pretty nice cams and they sound great. My buddy has a whiplash one in his and it really made it scream.
Engle cams.
Everyone has what they think is the best cam. It is all a matter of opinion. And the list will go on forever. I use Mopar perfomance it was what Carroll Shelby used and if it was good enough for him its surely good enough for me. And my car run fantastic...Bill
First thing you need to figure out is what gears you want to run in the rear, then if you want a different stall converter.
