hydraulic roller cam on small mopar LA ( help )
Old Dec 17, 2011 | 12:19 PM
q8_barracuda's Avatar
i have 1978 360 mopar LA engine and i wont installation hydraulic roller cam ,
what can i do to install it and what do i need part for install
preferred from summit racing
thanx to warm attention
Old Dec 30, 2011 | 04:30 PM
PK1's Avatar
PK1
Hughes makes the lifters with link bars that drop in and clear the lifter bores with out grinding. They make ones for oil system as is on the LA or "oil thru PR" if you want the stud mounted rocker heads... You do not have to worry about Cam walk like Chevys.
You can NOT use magnum roller stuff in the LA.
maca
Jul 10, 2014 08:21 PM
maca
Mar 12, 2014 11:50 PM
Gorts 5th
Oct 31, 2013 05:35 PM
ellisfan
Feb 15, 2011 04:26 PM
norcalmopar
Aug 6, 2010 03:51 PM
