10w-40 oil
Old Oct 29, 2014 | 06:09 AM
tattoopat's Avatar
10w-40 oil
I have a 2007 dodge charger srt 8 6.1 liter. I put 10 40 oil in is that going to be ok or should I change
Old Oct 29, 2014 | 07:15 AM
moparted's Avatar
use the factory recomened oil which isn't 10 40
Old Oct 29, 2014 | 11:41 AM
Probably calls for 10/30 Should be OK until your next oil change depending on where you live..
Old Oct 29, 2014 | 04:49 PM
Drag Pak's Avatar
I believe messing with the oil viscosity creates problems with the Multi Cylinder Displacement functionality, if so equipped?
Old Oct 29, 2014 | 06:25 PM
pro-tech's Avatar
Do not use any oil that is not recommended for that engine or any other engine for that matter..Todays cars will set a code for the wrong viscosity oil and it will play havoc with the VVT solenoids....not to mention all the other components that depend on oil in these close tolerance engines... That engine should be 5W20 synthetic blend or better... DRAIN IT and put the proper viscosity oil in.. I also would use Mobil 1 which is what Chrysler recommends.... Bill
inri
Apr 13, 2013 07:04 PM
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:34 PM
