1964 Plymouth Fury Convertible w/383
Old Jul 18, 2023 | 02:29 PM
dads64's Avatar
Hey guys, Maine mopar guy here, im new to the group and im here with some questions about a 1964 plymouth fury, it was my dads car, he owned and maintained it the best he could for over 50 years. recently my dad passed away and left it to me. id like to get some bugs fixed and learn as much as i can about this car. its always been a dream for me to drive it and i always wanted to own it some day. hes had it since before i was born. this car has 79000 original miles and has been restored before. but over the years its gotten some age and id like to freshen her up. meet Big Blue!!
Old Jul 19, 2023 | 08:21 AM
Kuvasz101's Avatar
Lucky you!! What a great memory gift. Sorry about losing your dad. I worked on these things for a living way back in time. On a beginners note, the oil is the life blood. A great non-synthetic oil is 10w40 Quaker State All Mileage oil. It ranked the highest in PSI wear protection of any conventional oil at a whopping 126000 PSI. Change the green antifreeze every 2 years, it will save you tons of trouble. Other than that. Enjoy!! Any questions feel free to contact me.
Old Jul 19, 2023 | 02:56 PM
dads64's Avatar
il defiantly message you, I have a few things I want to get sorted right away. Ever since I was a kid I remember this thing leaving puddles of tranny fluid on the floor. My dad has recently put a new transmission in it and it’s still leaking. It shifts nice and rides like a caddy but will need some front end work soon. It likes to dart from side to side and I believe it may need some bushings. Another thing I noticed driving it is it doesn’t really seem to have a kick down effect when trying to accelerate. We recently put a Edelbrock 650 double pumper but it doesn’t seem to have the get up it did when I was a kid. But then again I was a kid. I’d like to get this car up to performance like it used to be. These are just a few things I’d like to get sorted first. Eventually I’d like to pull the motor and detail it. Is this a pretty hard job for someone that has some knowledge but never takin a motor out on his own? I do appreciate any help I can get
Old Jul 19, 2023 | 05:16 PM
Kuvasz101's Avatar
Those trannys when they sit for a period of time tend to empty the torque converter which overfills the transmission causing a leak. Not definitely saying that's your problem. The kickdown could be just an adjustment on the rod (if it's still there with an aftermarket carb) that goes from the carb linkage to the swivel down to the tranny. Adjusted by turning out (loosening) for higher shift points and faster kickdowns. The tranny under normal acceleration should shift from first to second at 18 mph and 2nd to third at 36 mph.
As far as removing the engine, it all depends on your skill level. You could pull the engine and tranny in one shot after removing the motor mount hold down bolts and rear tranny mount, exhaust pipes from manifold and radiator plus hoses. I had them out in less than 2 hours on some. Others, well we won't talk about those.
Old Jul 19, 2023 | 05:45 PM
dads64's Avatar
I know exactly what you’re talking about when it comes to the adjustment on the rod by the carb my dad messed with it it just doesn’t seem to down shift when u want it to. Aside from that the car is a dream to drive. I’d like to get it fine tuned. I think I have a weak starter. After the car is warm it doesn’t like to start and most the time I kill the battery trying to start it after it’s warm. I probably should put a new battery in it, it’s probably 5-10 years old
Old Jul 19, 2023 | 06:53 PM
Kuvasz101's Avatar
It sounds time to change out the battery and maybe starter. A simple check without amp tools is see if the battery cable (positive) gets warm/hot while starting. The gas now has ethanol. Ethanol boils just over 170 degrees causing vapor lock. It could make a hard start on warm days.
Old Oct 31, 2023 | 11:55 AM
dads64's Avatar
thanks for the info, i plan to dig it out next spring and go through it. losing my dad this summer was hard and all i could really do is look at it, but i do plan on taking it to the next level. i know my dads dream was to do 4 wheel disc breaks, msd igniton, and a better carb. cause i know the choke dont work. you really have to pump it alot to get it to start after sitting for a month or so. we did take a few nice rides in it and it was a dream come true.. i appreciate all the help guys
Old Oct 31, 2023 | 01:04 PM
Kuvasz101's Avatar
Grief certainly can be rough. It moves at it's own pace. You can't speed it up or slow it down. On the choke note. Mopars (big blocks) after sitting need to fill the carb bowl back up. Mostly because they evaporate the fuel. That's why you need to crank it so much. I installed an electric fuel pump while leaving the existing mechanical one in place. The one I installed looks like an inline gas filter. I put an on and off switch under the dash using it to fill the bowl after long sits and then shutting it off letting the mechanical fuel pump take over. Works great! Ethanol gas (10%) unfortunately boils just over 170 degrees.
Old Oct 31, 2023 | 02:16 PM
I just crank them about 20 revolutions,,,, and then after that mash the gas pedal slowly to the floor about 3 times... let it sit for about 15 seconds and then turn the key.... Works like a charm most of the time..... Lights them rite up.....
Old Oct 31, 2023 | 06:30 PM
dads64's Avatar
I will have to try that thanks. I am just starting out. My dad and I would work on these cars together but I wouldn’t do anything I’d just watch him lol. But now I have to figure stuff out in my own. Like taking the tires off for example. I remember him telling me that the lugs had reverse threads?? Have you ever heard of this?
Old Nov 1, 2023 | 11:47 AM
Kuvasz101's Avatar
The left side had left-handed threads from the 30s to about 1971.
Old Nov 1, 2023 | 05:34 PM
dads64's Avatar
thank you for the help!
Rustybob
May 15, 2021 03:42 PM
GG1
Sep 27, 2015 05:17 PM
RachelKaylyn
Dec 11, 2010 07:12 AM
grumpydodge
Aug 27, 2009 01:19 PM
kat325
Jan 4, 2008 11:51 AM
