1969 Roadrunners
Old Feb 6, 2010 | 08:11 AM
roadrunnered's Avatar
Junior Member
1969 Roadrunners
Glad to be with this group.....I'll add some background here:
Background : I live in Redding Ca. about 180 miles north of Sacramento....I have been working on getting my '69 Roadrunner upgraded and updated to go doorslammer racing again.....I've been focused on the Nostalgia Dragster scene for the past 15 years and my poor RR has been up on jackstands the whole time.....
I've freshened the motor ...new 590 lift Purple shaft cam...new Isky valve train...new Barry Grant fuel system (Race Demon 820/Fuel Pump/Reg)....New digital 6 MSD with billet distributor...new Ron Mancini 727 (Griner TB valve body) 8" Turbo Action converter....Took out the SS leaf springs and am installing Cal Tracs with the mono-leafs and calvert shocks...Welded in Mancini's sub-frame connectors....Took out the Powr Lok pumpkin out of the Dana 60 and went to a Strange spool with Richmond 4.56 gears.....Had Mark Williams build a new 4" alum. driveshaft with 1350 spicer u-joints and their chromemoly pinion/trans yokes....took off the old HEAVY drum brakes and put new Wilwood Dynalite disc brakes all around.....New Griffen Alum radiator.....No money for paint, so she stays her old blue color for awhile...that's the color everyone is used to seeing her anyway....
My goal for this project is to run the car in the high 10 second area...Best ET historically for this car is 11.64 / 116 miles per hour...That was in 1994....
I'm hoping to be test firing the engine by the end of the month and get her on the track shortly after.... I'll be racing the NHRA Heritage Series with the dragster and in between those races I'll be tuning the Roadrunner at our local track (Redding Dragstrip)...Hope to run a few Mopar races and some select nostalgia hot rod events.....
Would love to hear from other Roadrunner owners...I've owned 4 of them since 1969.....I've owned the present one since 1987....
I submitted a few pix on the albums part of this forum under Roadrunnered's Roadrunner......
Old Feb 6, 2010 | 08:29 AM
its a 440 right?
Old Feb 6, 2010 | 08:48 AM
Junior Member
Thank you, nice to be aboard......yes it is a 440 bored 30 over.....
Old Feb 6, 2010 | 10:52 AM
John Van's Avatar
Welcome! Always liked those roadrunners. Setup sounds good,what heads are you using?
Old Feb 6, 2010 | 08:08 PM
Junior Member
I'm running a set of classic old 906 heads...they have been ported, bronze bushed with valves at 2.14/1.81...since I'm sticking with a solid lifter non roller config for now I felt that the 906's will be fine....They obviously don't flow like the aluminum heads but I'm not trying to go max out with this car....Hi tens will be fine and fun and hopefully not break parts....Hi tens in a big car like that is a lot of fun....We'll see.....
Old Feb 7, 2010 | 03:44 AM
Welcome to the forum.. Good luck on the racing... It gets into your blood for sure!!!!!
mike639
Apr 11, 2012 07:09 PM
