1970 dart 340 6 pack
I am trying to finish of my 1970 Dart 340 six pack build. Where I am having issues is throttle /kick down linkage. Anyone out there that has done this? Any help would be appreciated ty all
https://www.herbsparts.com/products.asp?cat=849
If you have the patience, you can assemble/fabricate your own from a combination of miscellaneous "A" and "E" body pieces. The one piece "E" body kickdown linkage rod from the bellcrank down to the transmission may not fit an "A" body due to firewall constraints. You may have to use the three(3) piece section (2 rods and another bellcrank) from an "A" body from the upper bellcrank down to the transmission. |
Have you thought about using the loker kick down cable kit ?or check with Brewers performance for factory style set up
