1970 dart 340 6 pack
Old May 14, 2018 | 04:25 PM
King_viper98's Avatar
I am trying to finish of my 1970 Dart 340 six pack build. Where I am having issues is throttle /kick down linkage. Anyone out there that has done this? Any help would be appreciated ty all
Old May 14, 2018 | 09:22 PM
Drag Pak's Avatar
https://www.herbsparts.com/products.asp?cat=849
If you have the patience, you can assemble/fabricate your own from a combination of miscellaneous "A" and "E" body pieces.
The one piece "E" body kickdown linkage rod from the bellcrank down to the transmission may not fit an "A" body due to firewall constraints. You may have to use the three(3) piece section (2 rods and another bellcrank) from an "A" body from the upper bellcrank down to the transmission.
Old May 15, 2018 | 07:55 PM
Have you thought about using the loker kick down cable kit ?or check with Brewers performance for factory style set up
boggs69camaro
May 15, 2018 04:50 PM
bmaudlin
Jun 29, 2013 09:18 AM
sethjof
Apr 25, 2011 08:14 PM
stovepipe699
Feb 5, 2011 09:16 PM
cobra_4
Jan 27, 2011 11:45 AM
