1974 swinger engine swap
What year is the 318, what is it out of?
Is this a pre-68 318, aka "poly?" Then no
If this is a magnum, some differences from below
If this is a LA series 318, then:
"The factory way."
You'll need a V8 K member (front cross member)
"the non factory way." Go here and order what is called "swap" engine mounts, which are special after-market mounts that hook to the /6 K member and allow you to bolt in the V8
http://www.engine-swaps.com/
If you have a stick, you'll need a different bell, flywheel, and clutch, and probably some clutch linkage pieces
If you have an automatic, you'll need a long shaft either 904 or 727 to fit the V8, along with related hardware. This gets tricky, as "Ma" balanced the external balanced engines like the 260 by using weights welded to the converter. You can knock those off, for an LA 318, which are internally or so called "neutral" balance
You'll need a "car" engine pan as opposed to a pickup or van pan, exhaust manifolds to fit the body / engine combo. Generally, van / pickup manifolds won't work.
Obviously, you need exhaust system
Radiator "might" work. The top connection is on wrong side, but you can use a flex hose.
If you have power steering, you'll need a pump and brackets to fit the 318, and compatible pulleys. Nothing off the slant will work, maybe except for the actual pump itself
Minor changes in the wiring harness, pretty easy. The alternators are the same so long as they are 1970 or later
"The factory way."
440, could he just not find some .087 torsion bars and the motor mounts(no k-frame replacement) from Schumacher.
http://www.engine-swaps.com/Pages/Products.html
Frankly, I'd go with much larger than V8 factory T bars. MUCH larger. These cars were "under" sprung badly. The fact is, it is not the DESIGN of the suspension that is so bad, it's the springs, lack of brakes, anti sway bar, and shocks, along with junk factory tires, that made these cars such mundane drivers.
A 74 should already have disc brakes. The addition of decent T bars, re-work the rear leafs, even a factory front anti-roll bar, and along with new parts and alignment, and good shocks and tires, and these cars WILL handle.
Profyrfyter
Dec 17, 2020 01:22 PM
