Mopar Forums (/forums/)
-   -   1991 Dodge W150 transfer case (https://moparforums.com/forums/f4/1991-dodge-w150-transfer-case-9237/)
Jake Weaver Apr 13, 2011 01:29 PM
My 1991 Dodge truck will not shift from 2H to 4H or N or4L. The linkage feels like it is moving but nothing happens. Do I have a linkage adjustment problem or an internal one. What is you best guess. Thanks
78D200 Apr 13, 2011 04:12 PM
You should look under the truck while someone is trying to move the shifter. The transmission need to be in Park or Neutral in order to shift the t-case and you should put tire chocks infront and behind the tires. A lot of the time the bushings are worn out and need to be replaced. Any decent parts store should have them for $10-$20.
