2010 Dodge Challenger Climate Controls out!! Need Help Please!!
Hi, I have a 2010 Challenger. My Climate Controls are
Not working have no power no lights and even when off it blows Hot air!! I jumped it about a month ago due to a dead Battery and since then my controls to hot/cold Defrost and A/c Buttons don't work I've checked the fuses and none seems to be Blown!! In the trunk as well as the hood fuse boxes. Also both cigarette lights are out as well! Don't have a clue to what it is!!! |
Wrong area for post but...
If you use jumper cables on the car you may have damaged the computer or caused it to default somehow. Go to a dealership and have the codes pulled off and/or explain you got boosted. They will probably know what the problem is and how to fix it. Since the battery is in the trunk beside the spare tire where did you boost the car? |
Can't help with your problem. Welcome to the forum.... Be sure to check out the Mopar of the Month contest...
You need to check the relays that plug into the main distribution block. I don't have the book here but the grouping of such a large number of accessories sounds suspect. Check for corrosion and or looseness at the power distribution block as well.
welcome to the forum,, don't know, have not had any problems with my 2009
