2010 Dodge Challenger Climate Controls out!! Need Help Please!!
Old Apr 6, 2013 | 12:29 PM
Jay Weiner's Avatar
Hi, I have a 2010 Challenger. My Climate Controls are
Not working have no power no lights and even when off it blows
Hot air!! I jumped it about a month ago due to a dead
Battery and since then my controls to hot/cold Defrost and A/c
Buttons don't work I've checked the fuses and none seems to be
Blown!! In the trunk as well as the hood fuse boxes.
Also both cigarette lights are out as well! Don't have a clue to what it is!!!
Old Apr 6, 2013 | 12:34 PM
jacilynn_s's Avatar
Wrong area for post but...
If you use jumper cables on the car you may have damaged the computer or caused it to default somehow. Go to a dealership and have the codes pulled off and/or explain you got boosted. They will probably know what the problem is and how to fix it. Since the battery is in the trunk beside the spare tire where did you boost the car?
Old Apr 7, 2013 | 02:22 PM
Can't help with your problem. Welcome to the forum.... Be sure to check out the Mopar of the Month contest...
Old Apr 7, 2013 | 02:52 PM
PK1's Avatar
PK1
You need to check the relays that plug into the main distribution block. I don't have the book here but the grouping of such a large number of accessories sounds suspect. Check for corrosion and or looseness at the power distribution block as well.
Old Apr 8, 2013 | 02:18 PM
Old Apr 9, 2013 | 05:36 AM
rickyr's Avatar
welcome to the forum,, don't know, have not had any problems with my 2009
Kip42
Feb 19, 2014 11:43 AM
MilesP
Jan 25, 2014 05:59 PM
curtjr4
Jun 18, 2012 09:34 AM
ElDoradoPlumCrazy
Jan 23, 2012 02:35 AM
mikerp76
Sep 29, 2011 04:50 PM
