318 charger
Old Oct 17, 2012 | 03:25 AM
blakethecop's Avatar
318 charger
hi i am blake from australia just bought a charger from usa it has a 318 motor. i would like some info on how to increase power without spending mega bucks.i am a fitter and have worked on diesel engines but to be honest i could rebuild the engine but dont totally understand all the in and outs of what heads cams and valves are best any help would be great
Old Oct 17, 2012 | 03:54 AM
theFUSELAGE KING's Avatar
The 318 will respond to the usual "tried and true" tricks of the trade e.i. cam/intake/carb swaps......there are a million plus two recipes for getting more power from a 318. If I were on a strict budget, those items are where I would start first.
You might also find printed info a big help as well.........
Old Oct 17, 2012 | 06:05 AM
X2 on that book. I've got a copy of it myself and love it.
Old Oct 17, 2012 | 06:13 AM
rickyr's Avatar
Old Oct 17, 2012 | 07:54 AM
PK1's Avatar
PK1
Welcome.
Since you are in Australia do some research on Engine Quest and RHS cylinder head castings. I believe they are made in Australia and New Zealand. They are made for both the LA and Magnum 318 motors and will give you the biggest bang for the buck.
You can get these bare for short money and set them up with GM (Holden) parts which will keep your hardware costs down. Most engine shops sell these complete as replacement heads and use Chevy hardware due to cost.
If you have to tear into the rotating assembly pay attention to piston height to dial in compression.
With decent intake, headers and the EQ heads you will have an outstanding driver with modern performance numbers.
The book above is excellent and search this forum as many have done outstanding work with their 318s.
Good Luck!
Old Oct 17, 2012 | 12:58 PM
I would start with dual exhaust, 4bbl intake and 600-650 cfm carb. Make sure to get the correct Mopar throttle lever adapter for the carb for the trans linkage.
Also check the rear gear ratio if it has a 3.23 your ok.
I could have a 2.91 so a change would help
Old Oct 17, 2012 | 03:13 PM
Welcome to the forum... I also love the book in the replys above..... To each his own........
Old Oct 17, 2012 | 03:30 PM
Welcome aboard. Another good read is How to Hotrod a Mopar Small Block.
BuckNeccid
Jan 12, 2012 04:38 AM
olebrowndodge
Feb 10, 2011 03:28 PM
dustin2100
May 12, 2010 03:35 PM
68lover
Apr 20, 2010 07:23 PM
DartConvertible
Oct 8, 2009 11:59 AM
