hungrymark56 |
05-03-2018 05:27 AM |
67 dodge charger383
Hello and thank you for letting me join your forum! I have a 67 dodge charger 383. A friend of mine changed the timing set yesterday the timing chain marks were lined up like the old one. the car has a hei distributor I believe and wasn't touched! after the install I started car and it was running rough at a very low rpm 4-500. so my friend tried some carb adjustments but couldn't smooth it out under 1100 rpms he then checked the vacuum advance unplugged the little rubber hose and noticed there was no vacuum! could this be the problem? thanks Mark
