Gear troubles
Old Jul 22, 2017 | 06:21 AM
Simon Ballinger's Avatar
Gear troubles
I've got an 1975 b200 manual column shift with the 5.8ltr. Yesterday while out and about I took a tight corner on full lock and heard a grinding noise and after that couldn't get it out of Gear and the shifter now feels real loose , luckily it was a gear I could get home still using. It's had a full engine rebuild and new clutch, clutch feels fine and no noise coming from the gearbox. Any ideas why it's stuck in Gear? And what I need to Do?.
Old Jul 22, 2017 | 07:17 AM
Over time the column shifter will get sloppy and sometimes allow the trans to get into two gears at one time. You will need to get under the truck and move the levers on the trans to back to neutral. It might require you to remove the linkage from the trans, it's a good time to look over all the linkage for the shifter and take care of worn parts.
Old Jul 22, 2017 | 07:36 AM
it's pretty much what I was thinking as everything else seems fine,I'll strip it back tomorrow and fingers crossed that's all. Thanks
Old Jul 29, 2017 | 04:20 PM
Gorts 5th's Avatar
Smile
i had a super T 10 with hurst shifter and the bushings where worn so when shifted into 1st. The linkages rubbing it also engaged 3rd..
And man what a mess... I eventually replaced it with a automatic.
shrek101
Nov 1, 2012 09:33 AM
67r/t
Nov 24, 2010 08:54 AM
DartSwinger
Oct 11, 2010 01:58 PM
christineman
Jul 19, 2010 05:28 PM
Frank's 69
Apr 25, 2009 07:40 PM
