Hey there. I'm new. [If that's original.]
Guest
Posts: n/a
Hey, I own a '73 Plymouth Duster. I have a 225 Slant 6 in it, but I think I want a 318 or a 340 in it. It will just be a daily driving car. I don't plan on racing it, ever. It was my great grandma's car. I just want something that sounds nice. So, should I just keep the 225 or upgrade to a 318 or 340?
Thanks for taking the time to read this.
Guest
Posts: n/a
Well, I plan on making it a show car. I'm going to completely restore it. Although, I do want a bit of power in it. The car is like my family heirloom. My great grandma gave it to my grandpa. My dad left me before I was born, so, my grandpa gave me the car because I'm joining the Marine Corps here soon and its a going away present. Its a bit torn up because the car used to be in Michigan and they salt their roads. I want to restore this car before my grandpa passes away. This way he'll be able to see it how it used to be.
Guest
Posts: n/a
Sounds to me that just restoring it in its original form is what your after right now. If the 6 cylinder runs good just do a make over on the motor.If you ever become more interested in adding power to the car the 340 4 speed clutch is the way too go. I had one with a 340 4 speed not much around could touch it.You would have to build the rear end up a bit though cause you just have the light 6 cylinder rear in it now.
if you want a 4bbl carb clifford and offenhauser have some good pieces. if you want go mild, the factory 2bbl slant manifold is a good setup.
http://www.cliffordperformance.net/M...tegory_Code=MY
i went all mopar performance with mine, i think they have discontinued a lot of those parts though...
johnthegoalie
https://moparforums.com/forums/members/johnthegoalie/
he can definetly help you
