Lack of Oil
Old Jan 21, 2012 | 02:20 PM
Amos 33's Avatar
Lack of Oil
I have a 426 wedge I had blue printed in 1990 and am just now getting the project finnished. I pulled the distibuter and turned the oil pump to veirfy oil but am only getting oil on the drivers side of the heads, any suggestions would be apreiceated.
Thanks'
Old Jan 21, 2012 | 03:14 PM
Have you tried turning the crank while priming, this should align the cam journal transfer passage with the other side. I think they line up when TDC on damper is at approx. 10+2:00.
Old Jan 21, 2012 | 06:58 PM
You need a oil priming shaft to spin with a drill and rotate the motor like 500 suggested.
Old Jan 22, 2012 | 04:03 AM
Agree with both replies above... Als ... Welcome to the forum.... Be sure to check out the Mopar of the Month contest
Old Jan 22, 2012 | 06:39 AM
rickyr's Avatar
I agree X3 if you have an old dist. you can make a priming tool; welcome to the forum
Old Jan 22, 2012 | 10:39 AM
And while you're at it make sure both rocker shafts are installed properly
I dont know if the older engines had the "notch" in the end of the shaft. The book says
Old Jan 22, 2012 | 12:45 PM
Amos 33's Avatar
Than you all for your imput and welcoming me to the Forum.
I am using a shaft and drill motor to turn the oil pump. The shafts do not have the notch mentioned, I have the Chilton hard cover book also and tried to figure this out on my own but needed this imput, I ordered a new long ratchet and a deep socket so I can spin the crank, I'll let you know what appens, Thanks' again.
Old Jan 26, 2012 | 02:38 AM
Old Jan 29, 2012 | 05:33 PM
challenger's Avatar
Welcome Amos hope you stick around and have a great time
dzltd02
Oct 28, 2008 08:25 AM
mukky
Aug 7, 2008 09:39 PM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:34 PM
