NEW AND NEED HELP!
Old May 26, 2022 | 06:03 PM
JosiasDenzler's Avatar
NEW AND NEED HELP!
Hey everyone thanks for taking the time! I just acquired a 1985 Dodge Diplomat and I love this car but it need work to get it running to par. It's a bit slow on acceleration and I get about 100 miles off of 12 gallons. I don't know much at all about carburetors or cars at all but I'm willing to learn and I need help!
Old May 26, 2022 | 09:56 PM
There’s a lot of possibilities here, the 318 was a smog dog in the first place but it could probably use a new set of plugs. There’s a chance the converter is plugged sorry I can’t remember if your car is lean burn or not but if it is your problem could be there.
Old May 26, 2022 | 10:58 PM
unfortunately the lean burn..just changed the plugs cap and rotar. Also cut the cat off recently. So far all of this has helped a bit but I'm at a loss of where to go next. I'm still getting killed in acceleration and my mileage is like 100 miles to 12 gallons
Old May 27, 2022 | 03:06 AM
Archer's Avatar
J -
Timing? If the motor was never rebuilt, the timing change could have slipped.
Bad or poorly configured carb? Try playing with, or rebuilding, it.
Vacuum leaks? Get a vacuum gauge and see where it is. Spray a water mist around the carb and vac lines and listen for changes in rpm.
Dying motor? Do a compression check. If the motor is sound, you can do basic bolt-on mods; the only thing you can't readily fix is the compression ratio.
Sorry, not a lot to go on.
Old May 27, 2022 | 08:16 AM
Originally Posted by Archer
J -
I used carb spray the other day try to locate it but I do have a vacuum leak somewhere. When I spray the cleaner towards the back of the carb the idle drops but I'm still having trouble finding the source. I can hear the leak at some points when I step on the gas like it's sucking for air. Maybe the air filter gasket? Between the carb and the housing?
SHELBYDAKOTA#1115
May 26, 2022 07:21 PM
48desoto
Sep 15, 2012 05:46 AM
AzbestoN
Oct 29, 2011 04:11 PM
ryguy
Mar 18, 2010 04:06 PM
bobmich
Aug 16, 2008 12:54 AM
