Ocala is on the air
Old Oct 25, 2011 | 02:34 PM
kayakdon's Avatar
Wink Ocala is on the air
Hello to all Mopar forum fans.My name is Don. I'm brand new, recently moved to Ocala, Fl. from Miami. I have a semi body/ragged out '65 Plymouth Fury II 318 that decided to drink the water from the cooling system into the crank case. The symptoms were merely that she would stall at stops but otherwise ran OK. Seeking answers I pulled the distributor which I discovered was caked with mud ( emulsified oil ). After draining I had to return to Miami for 3 months which allowed for more of the, very slow drainage to continue. After several more mos. I am now beginning the repair which I think is the very corroded aluminum timing cover that the water pump mounts to.I got stuck at the crank pully mount bolt not knowing if it has right or left hand threads. If someone out there knows, please let me know.
Old Oct 25, 2011 | 02:48 PM
Could be timing cover leaking water into the oil pan. If your taking about the harmonic balancer large bolt it is right handed. You will need a very long and large breaker bar to bust that bolt loose otherwise a really good 1/2" air impact. You will then need a harmonic balancer puller that you can borrow or buy at an auto parts store.
Old Oct 25, 2011 | 08:29 PM
Silverick's Avatar
Welcome to the forum and good luck with your little project!!
Old Oct 25, 2011 | 11:40 PM
When you replace the WP housing Use a 50/50 mix of anti freeze and make sue the engine grounds are good and clean to prevent electrolysis.
Old Oct 26, 2011 | 05:35 AM
rickyr's Avatar
welcome
Old Oct 27, 2011 | 03:27 AM
Welcome Don... Glad to have you on here..... Be sure to check out the Mopar of the Month contest... See the sticky for the simple rules and then next month you can help choose the winner...
Old Oct 27, 2011 | 07:09 PM
challenger's Avatar
Welcome Don glad to have ya' here and good luck with your little project , let us no how it goes
Old Oct 29, 2011 | 04:06 AM
hmiller79
Jun 1, 2019 09:30 PM
parrothead6970
Feb 17, 2011 07:14 AM
CadVetteStang
Nov 19, 2008 05:32 AM
mbridge1
Jan 28, 2008 09:30 PM
rubadub
Dec 6, 2007 08:55 AM
