Mopar Forums (/forums/)
-   -   OVERDRIVE (https://moparforums.com/forums/f4/overdrive-6207/)
BIGJOHNSMOPARS May 15, 2010 07:35 AM
OVERDRIVE
Hi' i'm new to this stuff so bare with me. I have a few old mopars 65 Belvedere with 440 and 4 speed also 64 fury convertible thats not done. My love is the belvedere. I'm looking for some info it's 3:90 gears and runs about 3200 rpms at 55. I'd like to put an overdrive in it. I looked at TKO 5 speeds but heard they don't like to shift over 6 grand not that I do it all the time but I do and if I'm going to spend $3000 on a trans it should do that. Also looked at gearvender about same price and I like the gear spliter. I have heard the 833-A is the best trans you can get. I would appreciate any info thak's
78D200 May 15, 2010 08:29 AM
SCAMP TRAMP May 15, 2010 08:37 AM
I've used this Richmond 5 speed with a 440 no prob .... on the higher $$$ side but a really tuff gearbox
http://www.jegs.com/i/Richmond-Gear/...oductId=773418
67 GTX May 15, 2010 04:02 PM
but doesn't the richmond not have an overdrive?
SCAMP TRAMP May 15, 2010 05:50 PM
1st 2.89 or 3.33, 2nd 1.89, 3rd 1.31, 4th 1.00, 5th .77
BIGJOHNSMOPARS May 15, 2010 06:50 PM
But would the Richmond fit with out altering the floor ?
SCAMP TRAMP May 15, 2010 07:30 PM
I had to on the A body it went into but only because it was an auto to start with, yours I don't honestly know
SCAMP TRAMP May 15, 2010 07:34 PM
... or change your rear gear to a 3.73 or 3.55, still get a good launch and drop the rpm at 55 - fraction of the cost that a new trans is going to be
67gtxclone May 15, 2010 08:19 PM
Welcome! I have a 67 Belvedere GTX clone with the A833 4 speed. There are two flavors, the 18 spline shaft and the 23 spline shaft. The 18 spline is the more stout of the two. I also thought about an overdrive trans, but just could not spend that much money, so I got rid of the 3:91 gears and went to 3:55 which is working out fine for me at less than a third of the cost of an OD trans.
BIGJOHNSMOPARS May 16, 2010 04:03 AM
I have the 23 spline it's seamed to hold up. I had broke a lot of things two 8 3/4 and a drive shaft. I know a lot of people arn't going to like this but I put a ford 9 inch in and that held up. I wanted the dana but I had the 9 inch. anyways you are probably wright with the gears. I just think it would be nice to have the best of both wolds.
SCAMP TRAMP May 16, 2010 10:12 AM
nothing wrong with the 9" John use them myself .... got 1 for sale right now
40” wide, 5:13/spool, 33 spline axles..... lol want it
MReeves May 16, 2010 07:05 PM
Welcome to the forum.....
