piston ring filer
Old Dec 22, 2009 | 07:18 PM
Cracocuda's Avatar
Unhappy piston ring filer
I have to file the piston rings of my mopar project to fit the recomended specs.The tool for this task is expensive for this one time job. This tool looks simple.If someone here has any idea to make a home made ring filer, you are welcome.
Old Dec 22, 2009 | 09:03 PM
theomahamoparguy's Avatar
If you clamp a thin file in a vice (with the file parallel to the ground) and hold the ring steady with both hands, you can set your gap by moving the ring back and forth, filing both sides of the gap. I guess you'll want to debur it after wards. (Small stone in drill motor). Use a medium file, be careful it comes off easy. Set your ring back in the bore using an old piston to square it up. Use feeler gauges to check dimensions.
Old Dec 24, 2009 | 04:18 PM
Cracocuda's Avatar
Smile Piston Ring Filer
Good Advise. Thank you for your help.
1970 Polara
Aug 29, 2013 12:32 PM
thedusterridesagain
Mar 7, 2010 03:57 PM
sgp7679
Aug 25, 2009 04:44 AM
jar84203
May 13, 2009 03:04 PM
67 Coronet
Nov 5, 2007 03:07 PM
